Need help with 1993 225 Johnson Ocean Runner
fireranger40
I just bought a used boat that came with the 225 Ocean Runner after following the troubleshooting guides for no spark, I went ahead an ordered a new power pack. I would like to add an rpm gage. Anybody know where would i connect this to?
The fuel line seems to have an additional connection that is capped-off for oil injection. Can i just buy any oil injection tank and hook it to that line?
Thanks for the help!
ezeke
Re: Need help with 1993 225 Johnson Ocean Runner
You may be able to add the oil tank. The system needs to be tested. A lot of owners switched to premix when the electronics failed and just used the OMS as a lift pump rather than a mixing system because of the cost of replacing them. The pump electronics cannot be repaired, nor can the oil side of the pump. There is a kit to keep the gasoline side repaired, so it can be used for premix.
You may find this thread helpful: http://continuouswave.com/whaler/reference/VRO.html
If you have the side mounted control you may have the plug for the tachometer built in below the ignition key; look for a black three wire plug.
Otherwise you need to take the positive and negative wires from the ignition switch and the gray sender wire from the main harness. You can connect a blue wire for lighting to one on another gauge.
fireranger40
Bless your heart! I DO see a plug under the ignition key! Now? IF I buy a tach from Napa or anywhere else? How do I hook-up to that plug? :confused:
ezeke
The BRP OMC dealers have tachometer kits that include the harness. Teleflex charges a lot for the harness as an accessory for their tachometers. I have no idea what Faria provides. I use the OMC BRP kits but I know the Teleflex tachometers are good, it's just that the wiring harness is overpriced in my not so humble opinion. http://www.iboats.com/Teleflex_Tach...14434833--**********.181490332--view_id.40245
Check with a dealer first and then do some price comparison: http://dealerlocator.evinrude.com/en/410000.shtml
