Slamnslash
Thread starter- Joined
- Sep 24, 2016
- 5
Thank you in advance for the help.
I have been having an issue with my coil overheating causing a miss. There are several threads that I have found and have come to this point because I cannot find the issue.
Let me start with the details.
Boat is a 1999 Maxem 1800SR
Motor was blown and a replacement was installed but ignition system was not carried over. This boat was originally built with the TKS style electronic ignition.
The donor motor had points.
Now the engine harness plugs into the boat harness and everything is working.
What I have done.
I added a Petronix ignition and flamethrower coil with an internal 3 ohm resistor. I am running the coil and igniter from 12vdc off of the choke wire.
Voltage at the coil was 13.5 running. I added a resistor and brought it down to 11.5.
With the original points and coil it would start to miss and die after about 20 minutes of running. Now it can run for about an hour and does not stall (yet) but starts to miss.
I am thinking I might have an issue with my tachometer and it causing the coil to heat up.
I notice that if I am using the trim, the draw in power will cause the coil to start missing shortly after the voltage has stabilized (draw doesn't seem to cause the miss but the continuing draw and recovery seem to have more of an effect.)
My questions are;
Should this tach run to the alternator or to the coil? Could the change from the newer style TKS ignition back to the old point style have caused a compatibility issue with the tachometer?
I plan on taking her out and leaving the tach disconnected and see what effect it has but can the tach be hooked up to the alternator? I am pretty sure looking at diagrams that the alternator has a tach terminal.
What I have done.
My questions are;
