need help with a 140 Mercruiser
Kootenay
I have a 140 I/O merc and need to replace the prop shaft seal. Do I need special tools and also the nut behind the prop shaft is it left or right thread? Hopefully someone can help me.
Alumarine
Re: need help with a 140 Mercruiser
Welcome.
I can't help you out other than to suggest you move this question to the Mercruiser Forum.
Chris1956
Honorary Supreme Mariner
Replacing the prop shaft seal is a difficult task. The bearing carrier nut is right hand thread.
Are you sure that is the leaking seal? Have you replaced all the other seals? They usually fail first.
BTW - I recommend you repost in the IO forum.
