Need help with buying used tilt/trim unit..
EBENZER
guys im looking into buying a used tilt/trim off merc..150.its already off the motor.is this easy to check. Can i just take the ground wire and ground it and touch each lead(blue and green) to positive of battery without soleniods to see if it works before i buy it..
merc850
Re: Need help with buying used tilt/trim unit..
and I had mine stop working Sunday because the brushes were gonePT-motor.jpg so when you buy it take the end cap off and check the brushes and maybe clean the commutator with very fine emery cloth.
