moser42
- Joined
- Mar 17, 2007
- 56
Here's what i have: 9hp Elgin Serial # 5948611065
Model # C571594861
What year is this motor and what other info do you have on this motor, is it a good or bad motor to fix up?
This motor was in a shed for a long time and I recently brought'er out and the motor turned out to run fine but it wouldnt not shift correctly.
After taking it apart i've found the shift cam or shift plunger is worn in the bottom gear housing and is causing the shifting problem.
Where can I get one of these shift cams or shift plungers? This is the only part the motor needs and once I find it I can go fishing! please any help with finding this part would be very very greatly appreciated!!
Thanks alot!
Model # C571594861
Thanks alot!
