Re: Need help with info on VIP Vindicator
Paul ,
It's a OMC King Cobra Setup. It is a Ford 460 Engine. It is rated at 340 HP. There should be a Serial # plate on the valve cover on the port side of the motor. There is also a ID plate on the port side of the outdrive just above the area where the upper and the lower drive pieces bolt together.
The best thing to do is get you a factory service manual and parts catolog. I got mine from Searayman13 on Ebay. Spend some time in the forums and you'll learn alot about your boat.
There isn't really a owners manual per se available. If your lucky you might find one on Ebay but as far as the boat itself....nothing.
Let us know if we can help with anything. Lots of info here on Iboats!
P.S.: Welcome to Iboats!
