kentuckybassman18
- Joined
- May 12, 2004
- 23
i got a 1983 johnson 150hp. motor, it will not start, when i hit the key to start it the little gears on top of the starter will not go up enough to turn the flywheel, the little gears on top of the starter will turn but the flywheel will'nt turn? is it the starter bad? or could it be the solenoid bad? what is the solenoid for and what does it do? some times the motor will start,i can go back to the motor and pull that little gear up that is on top of the stater and it will turn the flywheel and it will start, but most of the time it will'nt start, because the little gears on top of the stater will not go up enough to hit the flywheel and turn it? so what might be wrong? help please!! thanks!!
