Need help with Minnkota power up
dfrants
does anyone know if I can wire my minnkota power up trim unit to the switch in the throttle handle instead of using the two button switch that came with it? this unit has 3 wires, red, white, and blue. thanks, Don
ndindy
Re: Need help with Minnkota power up
Should be able to, figure 1 wire will be power, the other 2 will be the switched wireds, 1 for up and 1 for down. A multimeter will be your friend here.
