Need help with model/serial # identification
GaJeff
I have a 2001 salt water series 200hp yamaha outboard. I'm swapping this motor in place of a 200hp Johnson. I found the ID numbers for the yamaha so I could download a manual for the wiring diagrams. Well I notice that mine has carbs and the manual states that it should have fuel injection.
Further investigation leads me to find that someone has changed the engine to carbs on a fuel injected drive. The wiring is not the same. I need to find out what kind of engine I have. Is there any ID numbers on the engine itself or is it just on the transom brackets. Ill post pics tomorrow evening. This is kind of weird because the outboard shop told me there is no way of telling what year engine has been replaced. He said it could be from the 80s-90s. That really narrows it down.
Jeff
GaJeff
Re: Need help with model/serial # identification
Bump TTT....
Johnny Otter
I have found this page to be of use. Work backwards for your specifics:
Reservdelar Yamaha, Originaldelar
Click on 'show extended listings' and then 'search model types'. It might help.
Good luck!
John
ps If you use Google Chrome, you can translate the page
