need help with my trim
road_runner
my trim will not work but a few sec i have replaced my switchs but still have the same issu
Bob_VT
Re: need help with my trim
Welcome to iboats
What trim system are we working with? Do you have relays or solenoids? 2 wire or 3 wire motor? Have you checked your fluid?
Without specifics ........ kinda hard to help.
HighTrim
..also is it just up, just down, or both ways? Check the fluid level first and bleed as already stated.
mrcj001
Most trim motors have a overload curcuit in them. You may need to take the motor to a electrical shop and have the install new brushes and if the overload curcuit is bad they can by-pass it. You will need to use a fuse between the motor and the battery if you bypass the curcuit.
