merc150
- Joined
- Jun 17, 2013
- 110
Hey guys!!
I have a 1994 19ft hydra sports flats boat with a 2003 mercury 150 carb motor. The boat is heavy and has many ad ons such as polling platform, front fishing platform, trolling motor, power pole and 4 livewells, 50 gallon gas tank, and i usually 3 people on the boat. Im trying to figure out which stiletto advantage prop to get its either the 17 p or the 15p (need bow lift thats why I have a stilletto) my original prop was a vengeance 17P and i got 5600 rpm @WOT (rpm the merc recommends) I switched to a 21p stilletto and only turned 4900 rpms @WOT then I bought a 19p stiletto and im only running about 5000 rpms @WOT. Im thinking 15p might put the rpms close to where they should be. Also ive tried raising and lower the motor on the transom. I have the cav plate 1 inch above the bottom of the hull (seems to work the best for this style boat). I have noticed with the vengeance prop the motor is a lot quieter through all of the rpm range and the stilletto. I understand that the motor is probably lugging do to not reaching full rpms. Back to the pitch what do you guys think? THANKS FOR THE HELP!!!
