Re: Need help with Prop. size
I agree... that motor shouldn't have any problems spinning a 21 pitch prop... should be up around 5k. I'd start checking your points, carb, fuel filter, throttle linkage(make sure your getting full throttle), etc.
I've been playing with a lot of cams on that program and typically the car/truck cams make more hp and tq all the way through the rpm band. The marine cams typically top out at 5k but make less power then the auto cams at 5k. The only difference I've noticed is where the auto cams make peak power at a higher rpm (which is typically too many rpm for a I/O at 5k+) but still make better power then the marine cams all the way through the rpm range.
