Need help with Quicksilver remote
love1u0
I have the T handle remote control with the throttle only button towards the bottom. <br />I cant seem to get the throttle only to work.<br />It is kind of a pain in the butt when Im trying to start the boat when it is cold.<br />Do I need to buy a whole new remote?<br /><br />Thanks,<br />Chris
KRS
Banned
Re: Need help with Quicksilver remote
Mine is the same year as yours, but a different manufacturer. I grab the bottom of the t-handle, where it pivots... and then pull it outward (left) from the control box to get mine into reverse.
tashasdaddy
mines a pain also, i popped the 2 piece trim cover off and soaked w/ WD40. it helped.
love1u0
Mine goes into forward and reverse gear fine, I just cant seem to get it to shift out of gear so all I have is just throttle.<br /><br />I push the throttle only button in and try to pull the base towards the port side, but it doesnt budge. :confused:
tashasdaddy
i just push my button and it disengages the gear shift. just push the button hard, and move throttle forward.
love1u0
Originally posted by tashasdaddy:<br /> i just push my button and it disengages the gear shift. just push the button hard, and move throttle forward.
I have tried this, but it doesnt work. My button<br />doesnt seem to be going in very far...maybe that is the problem?
KRS
Banned
Are you saying that it won't go into neutral while running, or even with the engine off?<br /><br />Did grabbing the base of the handle and manually pulling it outward help?
love1u0
Originally posted by KRS:<br /> Are you saying that it won't go into neutral while running, or even with the engine off?<br /><br />Did grabbing the base of the handle and manually pulling it outward help?
All of what you said is correct. I have tried just pushing the button in and then move the handle forward and, pushing the button in and pulling the handle base towards port side.
Don S
If it's an aluminum colored button just below and aft of the lever, have you tried pulling it? Some of them pulled out for Neutral only.
love1u0
Originally posted by Don S:<br /> If it's an aluminum colored button just below and aft of the lever, have you tried pulling it? Some of them pulled out for Neutral only.
It is black.<br />I tried looking for a picture of one on the web<br />with out any luck. I will try to snap a picture <br />of it tomorrow....Im off to work :D
Haut Medoc
Have you tried spraying any lubricant in there?...I would think that an '87 would have the fat black button that you depress......JK
melman
I think I have the exact same shifter. Mine would not come out of throttle only last week at the dock. After fiddling around with it for a while I sprayed some CRC lube in the hole after removing the button and nut that holds the shifter on. After spraying I did notice that one of the tabs on the end of the button had broken off and was behind the nut. After removing this it came out of neutral and shifted fine. Not sure if it was the lube or the plastic tab that was stopping it from coming out of neutral.<br /><br />Good Luck,<br />Melman
love1u0
watermark.php
<br /><br />Here is a picture of my remote. I took it apart and sprayed it with some WD40, but it didnt help.
love1u0
So, does it look like I have the push in the button, pull out the base type?
rodbolt
nope<br /> you have a push to throttle box. looks like a commander 2000.<br /> to opererate you have to push the button in and squeeze the upper trigger that locks the handle in the netrual detent.<br /> however there were many many problems with this box. there is a kit to fix it.<br /> it takes about 3 hours to dissasemble and reassemble the box and the kit is about 25 dollars.<br /> was a common failure.
love1u0
Thanks rodbolt....<br />Any idea where I can get the kit?
rodbolt
most any merc dealer. its not a hard job just a pain in the rumpus job. carefully inspect the throttle drum for damage and its not in the kit. <br /> occasionally we find one with a groove worn in it from the detent assy.
love1u0
Cool, I will look around and see what I can find.<br /><br />Thanks,<br />Chris
