Need help with shifter quicksilver
Donoway80
Took shifter apart can’t figure out how to get back together had pushed it forward to get set screw out do not know how line back up to have forward an reverse an neutral thanks for any help
Don't understand the problem fully
Throttle goes full forward to be able to remove "throttle only button" then the center bolt can be removed. It goes back together the same way
Donoway80
There is no center bolt model number is 88150a7
04fxdwgi25
I have the manual for all the Mercontrols, if you want it.
Too big to post here @24 meg
PM sent
Per the manual, shifter should be in neutral to reassemble.
  • Commander Classic.pdf
Donoway80
PM sent
Thanks a lot for info I tryed buying pdf online never got it no return email
