Mark42
- Joined
- Oct 8, 2003
- 9,334
The window frames in the photo below will have two wiper motors mounted in the little triangle shaped corners of the frames. Wires could be coiled and let hang loose to power the wipers. But I'm trying to come up with something a little more visually appealing.
What I've been thinking of is a set of "contacts" to make connection when the widow frame is closed, but breaks contact when the window is open. This will eliminate the wires that would normally be used.
There is about 1/2 - 5/8" gap between the wood frame and fiberglass top.
Any suggestions on what can be used as the contacts to fit in this gap?
I'm thinking some kind of stainless steel hardware, just haven't found anything inexpensive, spring loaded and clean looking.
Here you can see how wide the windows can open, so there would need to be a good amount of slack needed if wires were run to the motor. Not very neat or clean looking. Also don't want to run the wires along the outside fiberglass, because there will be foam strips there to seal water out. Thats why I'm thinking of contacts that only work when the window is closed.
