1976 75hp rude will not even begin to start to plane seems to have good spark on all cyl while at idle carbs have been rebuilt link and sync done comp is #1 120 #2 120 #3 118 no fuel problems when trying to bring rpms up sounds like its running on 2 cyl and just boggs down i took head off and piston walls looks great put new head gasket on started @4ft lbs and went to 16 ft lbs done this with the manual sequence again at idle every plug wire you pull off about stalls the motor tip the key and it starts on muffs come on guys help me or i will break down and trade my black max 150 to a small engine for my bass boat!!!!!!!oh yea moved 4 ftlbs at a time when torquing the head
