Need help!
maagee79
I'm restoring a 1976 formula castaway. I'm looking for pictures of one that is in good condition or restored. I've contacted formula and didnt get far with them so whatever anyone can help with would be great.
maagee79
Re: Need help!
also i am using a waterproof stain on the exterior trim that i have replaced. is it necessary to put a clear varish over the stain? or will the warerproof stain be ok?
chargerboy
Re: Need help!
Ever stained a deck on a house? Most waterproof stains only look good for a couple of years. If you want it to last, seal it with a UV inhibiting marine grade varnish. Double check to make sure you're using a product that will be compatible with the previous coat of stain.
maagee79
Re: Need help!
thank you i will look into that.
