This is my setup:
Prop ss 48-16988-18 I think it has a 13.5in diameter
1998 115hp mercury 2+2 max RPM 5250
1998 lund pro v 1775 32 gallon gas tank don't usually run full though
Maxxum 101lb
3 size 30 deep cycle batteries
1 cranking battery
8hp kicker motor 73lbs
3 bank onboard charger
Plus 2 live wells one usually full when fishing
usually fish with 1 other guy 240lbs or so
After I added the trolling motor and the 8hp my RPM's are way too high. At the moment I can't even have the throttle all the way down and I'm over max rpm that's without even trimming it up. I know if I trim it up I would be over 6000 RPM's easily but don't want to try. What would you guys recommend going to I'm looking to drop around 800 RPM's or so.
Maxxum 101lb
1 cranking battery
