need important advice on stain
1957champion
as the username suggests, im restoring a 1957 champion wood speed boat, im pretty sure its mahogany sides maybe the pics will say otherwise. the boat was stored in a barn for years rarely used and its in great shape, the past owner fiber-glassed it and just let it sit. me and my brother took the fiberglass off the sides and top (tore cleanly off in sheets) and left it fiber-glassed on the bottom so when we re-fiber-glassed it would be stronger on the bottom. sides and top are sanded smooth.
now the question is with the stain, we stained the top and love the color, but a friend warned against using oil-based stain because it may bleed into the future fiber-glass we're going to put on top of it and cause blemish. now its to late but the top has a oil-based stain on it and I'm worried if its too late, i dont know if i can sand it off or continue using it.
im going to put the stain info below with pictures of the boat, its tipped upside down now so you cant see the stained top, i can get pics of the top if there important.
brand: MINIWAX Wood Finish
Penetrates Stains and Seals
info:eek:il-based wood stain, it applies easily and penetrates deep into the pores of the wood and is ideal for staining furniture, cabinets, molding and hardwood floors.
chargerboy
Re: need important advice on stain
I have used oil based stain on wood and fiberglassed over with West System epoxy in the past and the results were just fine. Not sure about fiberglass resin.
1957champion
since i didn't buy the material for fiber-glassing (im restoring it with my brother and dad) im not sure but heres what we have Fiberlay (Polyester Resin Catalyst) and Fiberlay (surface seal)
chargerboy
So fiberglass resin. I don't think you'll have any problems, check out wooden boat forum, people on there have done it many times over.
