Need info of Evinrude 25HP motor, can't find anything
DamianJP
No sticker left on transom bracket. All I have is the number stamped on the circle on the power head.
G3002757, buts its not bringing anything up.
I think its a mid 90's. I know its a Evinrude 25hp.
Thanks,
DamianJP
DamianJP
Re: Need info of Evinrude 25HP motor, can't find anything
I figured out that that number I have "G3002757" is the serial number.
If I cant find the model number, how can I find parts for this engine?
Thanks,
DamianJP
hidef
Do you have a photo of it? Is it electric start or rope? Long shaft or short shaft. There should be one more welch plug hidden somewhere underneath the cowl.
Monte1961
Going to need model # much easier to get info!
D
DJ
Guest
The model number is there with the Serial number.
DamianJP
Its a Electric start only. Long shaft. The cowling says 25hp. The number off the welch plug Ive found so far is on the side with the rectifier and shift linkage. Were would the other plug be?
So far Ive found this info
Water pump kit 1985- an up
18-3382 Sierra W/Housing
Carb kit 1969-1995
18-7222
I used a 1995 Evinrude 25hp (EEOA model) to find these cause I think they cant be that diffrent or changed much
Plugs for gearcase
0307551
Washers for plugs
0311598
Thermostat
5005440
Gasket for thermostat
0329319
Gasket for cylinder head plate (water jacket plate)
0327674
So far thats the part numbers Iv'e found but need help to find the other welch plug to get the model number. Or need help to actully see if these numbers will fit my motor.
Thank you guys!!!
DamianJP
DamianJP
The circle stamped plug has a "M" and then G3002757, no other numbers. Plug is clean and has not looked like its been messed with or scratched off.
Were would the other plug and other places the model number would be?
Thank again,
DamianJP
Monte1961
look on port side towards rear
