Need info on light twin
thegun1942
Hi All,
I just purchased a model 4206 motor and I need spark plug info, fuel ratio info and model year.....Thanks:)
JB
Re: Need info on light twin
4206 is a 1937 1.4HP. I don't think that is a lightwin.
thegun1942
Thanks for your reply...This seems to be a sixties era 4 hp lightwin, the full serial # is: 4206 S 0007992. Any info on this motor would be greatly appreciated
Thanks....Ken:)
thegun1942
Hi again....Found out that Model 4206 is a 1972 4 hp direct drive engine...Should I use 24:1 or 50:1 fuel ratio on this one? The plugs that are in it are Champion J-4's...Can anyone tell me if that is the correct plug?
Thanks
Ken
tx1961whaler
Looked it up and a 4206 is a 1972 4HP. It is also a 1937 1.4HP, go figure....
50:1 mix
The chart I have lists it as a J6C plug. The J4C's will work fine. You might want to get J6C's if you do alot of trolling.
thegun1942
Hi... Thanks very much for the info on my 4206 evinrude...I'll probably go with the J-6 plugs, as I will be running @ low speed quite a lot. First thing I'll do is get the service manual and replace the water pump. :) Interesting that omc used the same model# for two such different engines....Again, thanks for your input and I look forward to participating further in this forum....Ken
