Donzi GT250
Thread starter- Joined
- Apr 22, 2011
- 110
Can anybody direct me to a link for the throttle cable adjustment procedure for my 1989 OMC 5.7 cobra with 4 barrel quadra jet?
I just adjusted my in gear idle to 575 rpm's with the fast idle screw but now I would like to make sure the throttle cable is properly adjusted to the new idle setting.
Is threr a way I can tell if the throttle cable needs adjusting to this new idle setting.
The old in gear idle setting was a bit low about 475 rpm so I just tweaked it up a bit and now my idle is a bit smoother.
My in neutral not in gear idle is 675 RPM now
I have a Clymers manual but it doesn't give the throttle cable adjustment procedure.
Thanks
Thanks
