Need link to Rodbolt's water pump replace post please...
Popster
Does anyone have the link to the post by Rodbolt on changing a waterpump. Thanks.
rodbolt
Re: Need link to Rodbolt's water pump replace post please...
depending on what year and what model will mean if the post is pertainant or not.
for V motors from 95 up and less than an F250 try a forum search on 115 water pump change.
Popster
Thanks, Here's what I found for others...
V4,V6 and F100 and larger 4 strokes, maybe some of the smaller 4 strokes as well since 1995.
http://forums.iboats.com/showthread.php?t=245497&highlight=115+water+pump+change
ok, its been a long time since I posted it so Ill do it again.
this pertains to all V4,V6 and F100 and larger 4 strokes, maybe some of the smaller 4 strokes as well since 1995.
dissconect the speedo hose if applicable.
remove 7 bolts holding the lower unit in place,8 on 3.1L and larger.
remove the case with the shifter in Nuetral.
place the lower on a suitable stand.
remove the 4 water pump bolts, remove the housing leaving the insert cup on the impeller. if the cup stays with the housing remove it and reinstall it on the impeller turning the drive shaft CW.
look closly at the plastic collar, you will see a split line.
using 2 screw drivers 90* from the split line carefully rotate the tips between the plastic and the ring.
the object is to keep the plastic from rising while the ring is coming off,
occasionally you get a stubborn one and then I simply cut it off with a chesiel.
parts are like 8 dollars, at 80 dollars an hour I wont play with it long.
next remove the impellor and the two flat washers and one wave washer.
then using a dulled chesiel remove the woodruff key. place the chesiel parallel with the shaft and drive the key down and out.
remove the plate and gasket.
remove the oil slinger from the upper bearing housing. carefully inspect the seals and garter spring.
remove the rubber dam and holder, clean corroded pocket as nessasary.
install the slinger and rubber dam, install the gasket and plate, install the woodruff key using a brass or Aluminium drift, install the impeller on the shaft, lubricate with dishwashing liquid.
place one flat washer,then the wave washer then the next flat washer down the shaft, slide the plastic collar down the shaft, top it with the metal lock collar.
A good tool to seat the collar is the aft prop spacer .
while pulling up on the driveshaft tap the collar in place.
now flip the pump housing over, install the small oring,install the cup making sure the alinment tab is seated.
grease the oring groove and install the oring in the groove.
now install the housing push it down while rotating the shaft clockwise, install the pump bolts.
install the gear case.
see how simple it is?
takes about 45 minutes if saltwater corrosion isnt an issue.
