HOLYSMOKES
- Joined
- Feb 10, 2008
- 32
I purchased a 1973 Reniell Classic Hardtop. The previous owner had a fishfinder that he decided to remove. Thats fine. The only problem is that the screws used to guide the wire down the back of the transom were removed...and yes...THROUGH the transom. I floated the boat and it was taking on water. ( I didnt know there was a leak prior to launching the boat)
SO, I decided to pull the boat and find out where the water was comming in at. Sure enough, three lil holes had water comming out of the transom. NOW, I have loaded many boats on trailers. They have all been bunk style trailers. This is my first roller type. I cant get the thing to line up on the rollers correctly. I am not a believer in "power loading" a boat so I just use the winch in the front and dock line in the back. I know there was a GOOD amount of water in the back corner of the boat driver side. ( Im sure to insert port / starbord here as my experience increases). BUT the boat sits cockeyed in the trailer...and low on the water logged side. (Right rear corner)
Do you have any advice for me as far as getting it loaded and seated on the rollers correctly? ANY help would be GREATLY appreciated!
