bkwapisz
Thread starter- Joined
- Oct 20, 2009
- 441
My little Ranger boat has a formed fiberglass console. On the inside of the front portion, I want to attach a flat piece of material (marine plywood or starboard) so I can screw things to it, such as my battery charger and other items. I'd like to know what those of you who have worked with these vairous materials would suggest as a) a material to use for the board, and b) what adhesive to attach the board to the inside of the console. The material thickness of the console is rather thin and I would like to avoid any visible fasteners from the outside of the console. I'll attach what pics I have of the console. The inside finish is rather rough unfinished fiberglass that at one time had some boat carpet apparently attached to it so the current finish looks like rough fiberglass with old carpet glue stuck to it. I was thinking of maybe using some marine ply with a copious dose of construction adhesive but wanted some direction before I proceed.
Thanks for any advice.
Brian.
Brian.
