Need Mercury remote tilt trim switch.
kknickelson
1994 Mercury 75 hp on a Lund 1775 Pro V tiller.
The remote switch is bad on the bow.
Anyone know where I could find one/
Thanks
sschefer
Re: Need Mercury remote tilt trim switch.
West Marine has the Cordura style that look pretty good. It's M-off-M (momentary - off - momentary) switch. You can also use a toggle style if you want.
Just remember, green is earth (down) blue is sky (up) and the poles on the switch are opposite of the switch lever, usually. Use an ohm meter to verify the change in continuity when you push the switch if you get confused.
