need more negative trim
randyray41
I have a 78 Evinrude 70 hp mounted on a CMC pt130 power trim unit. I need some more down trim. I was thinking I could place some washers ( about an 1") behind the engine mounting bolts on the top to allow for more down trim. If this is done there will be a gap between the engine mount and trim mount plate.
Can this be done? I dont know if that will be safe to keep the motor securely mounted. Any thoughts or suggestions would be appreciated.
interalian
You can get transom shims. I have them on my rig and they do the trick. They're about an inch thick at the top, tapering to nearly nothing.
randyray41
I ordered a set of shims from CMC. I dont have any means to lift motor with a hoist, etc. Any ideas of how and what needs to be done to install them?
Sea Rider
For what precise purpose do you need to count with negative trim ?
Happy Boating
Lightwin 3
There should be a lifting ring on the back of the engine block. You can rent a portable engine crane from most tool rental places.
randyray41
I cant trim it low enough to keep boat from porposing(sp) at low speeds.
kbait
Can you transfer some weight toward the bow? Fuel tank..battery(s)?
oldboat1
A come-along and a sturdy overhanging limb is enough to lift the 70 out of the way. Not sure if motor mounting height is a factor, but guess it might be -- maybe mounted a little too high(?)
interalian
Happy Boating
In my case, the transom angle on my tin boat is too shallow and I couldn't keep the bow down. Good planing trim was only a skoche above full trim-in (yes, pin at min trim). Now I have a useable trim and good planing trim shows lowish in the "trim range" on the OE gauge. Now, I can trim it low enough to make the bow plow.
