Tail_Gunner
- Joined
- Jan 13, 2006
- 6,237
Re: Need. More. Speed.
Not at all. You have a flat botom or a semi v hull and the fact that your hole shot was better is a good sign. I believe if you follow it down you will find raising the motor even more until it blow's out performance will go up. But at a price for top performance its called a set back plate.Do a search here on iboats...there will be volume's of info. So now your quest for speed is all up to you..Good luck
PS raising the motor allow the boat to rest on it's Tail..and bounce down the water
