I need some help please. I have called every place around for a used control box ... none available. I have also checked EBay and found a few that might work. But I'm concerned that one repair place told me that Tracker controls were unique and I would have to change out all cables, etc from motor ... is this true? I was hoping to be able to get a new control box and use the existing cables I have (listed below). Also, if I cannot find a reasonable control with tilt/trim ... can I use a separate switch? What about separate ignition/choke/kill? Thanks again!
From the motor it has:
the steering cable
Battery cables
the wiring harness from the red plug to a eight pin connector with
Black/Yellow | Red/Gray
Yellow/Red | Black
Purple/White | Gray
Tan? | Purple
another wiring harness to a six pin connector with
NO PIN | Gray
Brown/White | Black
Gray/White | Red
the steering cable
Battery cables
Yellow/Red | Black
Purple/White | Gray
Tan? | Purple
NO PIN | Gray
Brown/White | Black
Gray/White | Red
