Need new dipstick?
hostage
My dipstick and tube broke when we were changing the oil, didn't see one on iboats. Anyone know where I can get one?
Forgot to mention: 4.3L V6 Mercrusier Y2k
Thanks,
Hostage
wifisher
Re: Need new dipstick?
Any automotive store/dealer will have one.
wifisher
Highly doubtful.... Most marine dip sticks are a lot longer than you find on a car engine. Again, assuming he is talking about the engine.
Granted, but as long as you can reach the shorter stick, it will serve the same purpose.
kewlkatdady
is it the kind that fastens into the bottom of the oil pan on the port side of the motor?
That is marine only...
Don S
Thanks,
Hostage
Your dipstick hooks into the bottom of the oil pan, and the tube is also used for pulling the oil out of the engine when you change oil. So using some automotive type dipstick will mean you can't get the oil out of your engine easily.
Your tube and dipstick is a Mercruiser part only, do you have the serial number for your engine. If you do, most any site with the OEM parts lookup will allow you to fine the correct parts.
hostage
One prob is they did a shotty job of putting the serial number on the engine
