Need new exhaust manifold
Eddie Ray
Aq125a. 270OD 1985 trophy
I think I need a new exhaust manifold. I looked here in parts and did not find one? Where should I look?
If a put the hose to the small hole .water dose come out the large hole at rear. It comes out only in one small area . Not really enough flow. I assume the inside is probably clogged as well and not allowing a good flow,and causing some back pressure.
I am guessing there is no good way to fix this? That would be too easy,and boats are never easy!
Thanks in advance!
Eddie
