need NEW pulleys 4.3 L
kramerpage
Looking for new WP pulley part 15120 it's 5 1/2 in dia.
Also looking for engine crank pulley 90081-C.
My sheaves are worn.
Need PS and ALT pulley but I don't have them in hand for part numbers.
Seams like I install belts every year. Thanks aliment and tension is good btw.
Engine serial 0C616538
Fun Times
No. 97-4
SERVICE MANAGER PARTS MANAGERTO:
P/N 15120T Circulating Pump Pulley No Longer Available
Models
All MCM and MIE V6 and V8 Models.
P/N 15120T Pulley
This 5-1/2 in. (140 mm) diameter pulley was used on older engines. It is becoming No Longer Available. If this part number circulating pulley is needed, order the correct pulley kit listed below.
Pulley Kits
19692A 2 Pulley Kit. For V6 and V8 305 or 350 cid engines. Contains 7 in. (178 mm) diameter pulley, new V belts and instructions.
19692A 1 Pulley Kit. For V8 454 cid engines. Contains 7 in. (178 mm) diameter pulley, new V belts and instructions.
Here's your parts list for you,
http://www.mercruiserparts.com/selectSerailRange.asp?doc_nbr=4.3L++(2+BBL.)++++GM+262+V-6++1988-1992
http://www.ebay.com/sch/i.html?_sac...ankshaft&rt=nc&LH_FS=1&_trksid=p2045573.m1684
http://www.ebay.com/sch/i.html?_odk...TR0.TRC0.H0.X15120T.TRS0&_nkw=15120T&_sacat=0
Merc Power steering pulley part number 73873A1.
390-8637 or 809134 depending on alternator brand. 390-8637 is no longer available though.
God luck.
kramerpage
Thank you for the helpful info guys. The cost of the pulleys are staggering. I don't know what Im gonna do at this point. budget is tight on my restore.
Watermann
Maybe a trip to the wrecking yard with your pulleys in hand to match them up correctly would be an option.
kramerpage
I actually have a whole second set but they are not much better. They get a wear grove and some rust on em. The water pump and power steering seem to be the worst on both. Crank is not steel so they are in much better shape. I may just clean up my second set buy having a friend glass blast them and baked enamel. He did my outdrive and it's beautiful. That won't fix wear but give the belts a stable surface to displace their energy. I have no bone yards around my area. That would be cool. Like a kid in a candy store. Lol. Thanks
Watermann
After seeing what those pulleys cost it makes me think if I ever have to do the same with my 4.3L I would think about dropping the extra bucks and get a serpentine conversion kit.
kramerpage
I called Michigan motorz and they said there isn't one. Lol. That's what I need. Then your done with it.
kramerpage
I investigated that avenue to the end with no sure plan to retrofit. Im sure it can be done. I couldn't find a company with the knowledge I guess.
So I took the best of the crank, waterpump and power streering pulleys to a motorcycle shop in town. They will glass bead them down and powder coat them black for 25 dollars a pully. I was very happy to hear that quote. They are the folks that did my bell housing, gimbal and otter transom plate.
Here is before and after work they did on the sterndrive parts
rps20150616bearing_125758.jpg20150610_204844.jpgrps20150718_120914.jpgrps20150803_000436.jpg
Watermann
Oh yeah that powder coating job looks super! :thumb:
Bt Doctur
do yourself a big favor, install the missing grease fitting for the upper bushing
kramerpage
Hi BT DOCTOR
I went thru this with you on the rebuild and you said I didn't need it since my shaft has a grease gally from the top to the bottom internally. You stated I was Lucky to have that type of shaft.
Thanks for watching out for me DOC. Here's the pics from that post.
kramerpage
Well I got the three pulleys back today from the paint shop. I am very happy with the results. Slowly pecking away at this project.
