Re: Need plug gap on 1980 Evinrude 25 hp?
Hi River Trapper<br /><br />If it backfires, you probably have too lean iddle mixture ( try to turn iddle mixture screw 1/8 turn out ) or your sync´n linck it not properly adjusted. Check to see if the trottle opens before the ignition cam roller reaches center of the two small timing marks on stator plate, above carb.<br /><br />It will always backfire easyer on muffs, cause of no backpressure. <br />When back in water do the procedure of adjusting iddle mixture, with boat mooving freely in forward gear. Remember to warm motor up first.
