Need prop help 24' & 70hp
flotebote24
NEWBIE HERE AND NEED PROP HELP. I HAVE A 24' HARRIS PONTOON WITH A 70hp JOHNSON. THE OLD PROP IS TO CORRI-ED AND I CAN NOT READ THE MARKINGS ON IT. I THINK IT'S ABOUT 13.5" IN DIAMETER FROM LAYING IT DOWN AND TRYING TO MEASURE IT. I JUST NEED A PROP TO POCK AROUND AND ALSO TO GET TO PLAN AN JUST NORMAL RUINING. NOT MUCH INFO THE GO ON SO ANYTHING CLOSE WOULD HELP.
THANKS IN ADVANCE
GARY B
hwsiii
Re: Need prop help 24' & 70hp
Look under the prop nut, and if you can't find it there bring it to a prop repair shop and they can tell you exactly what it is.
H
flotebote24
I have tried to see what it says on the prop but it's not readable, even sprayed rust and corrision remover on it and no good. Will see if I can find a prop replair place close by.
Thanks
hwsiii
Let us know when you get the pitch of the prop and your WOT RPM and GPS speed and we will help as much as we can.
H
