need quick answer.....help
alcan
Re: need quick answer.....help
Hi Poolshark<br /> Where on the propshaft would you like this measurement?
MR TWISTER
HEY MY MAN.....I'M ALWAYS LOOKIN' FOR A GAME. LETS PLAY SOME.
alcan
Hi Poolshark<br /> The prop nut, Part# 376501 is a dealer part. They don't list a size. There were three prop choices. #383629 9"X10"std.<br /> #379717 9"x9"<br /> #592959 9"x10" weedless.
poolshark38759
thanks alcan did help....<br /><br />we have a couple af marine shops about an hour away..will check with them on that part no....<br /><br />i have a prop that was given to me that will fit (come off evinrude same year/hp) but dont know size or pitch...how do you tell??<br /><br />i have a 14' PolarCraft with a front deck that i extended ~2ft with 1/2" plyboard and a rear bench with a TohoRig(from cabela/bass pro) livewell..dont really care 200mph with hair on fire but dont want to be grandpa on a sunday poke around...i fish delta oxbows mainly..what size would you recommend...
poolshark38759
left info out in last reply..<br /><br />rear bench and a tohorig livewell that is pretty well centered in boat...boat moves real good with a 36lbs thrust trolling motor..
rickdb1boat
Poolshark,<br />I would go with the 9" X 10" Prop, which is rated for a "Normal" load for your sized boat . This should put you in the ballpark as far as WOT RPM's.<br /><br />Does the Prop you have, have any numbers or letters on the hub??
poolshark38759
not sure..will check on it tomarrow...<br /><br />do you preferr pin-drive or spline-drive props....i have a foot from a parts motor that have spline drive but prop is spun out...
rickdb1boat
Spline Drive, but it depends on the Motor as to what you can use. Let us know the numbers if you can find any and hopefully we can cross-reference it.
