Gas Giant
Thread starter- Joined
- Aug 8, 2010
- 239
Ok, to start, I bought a great running Force 50hp outboard. Seller said it was an '87, and it has a few US Marine stickers on it. I'm hoping to swap out my dead Suzuki with this engine this weekend and finally, for the first time, be able to use my boat for something other than to mow around.
First off, I can't find the model number. Through searches, I found that the model number was on the swivel bracket, but whatever was on there has been painted over at least once and no numbers or ID are visible anymore. In my Clymer's manual it shows two wiring diagrams for 1987 Force engines, 1987B and 1987C. Do any experts out there know a way to tell which one I have; I'm just not experienced enough yet to figure it out. (Assuming the seller was correct about it being an '87)
Ok, on to issue number two, which will probably have to be dealt with after issue number one is resolved. This one should be fairly simple for some of you.
In the wiring harness from the engine, I have the following wires: Red, Black, Yellow, Green, Blue, Purple-ish and White.
The manual also shows the following terminals for the ignition switch: C. B. M, I, another M, and S. The one from my boat is basically the same, except instead of an I terminal, I have an A terminal. (The A terminal is where the Ignition wire was wired to with the old engine, I assume that the "I" terminal in the manual is basically the same thing.....or not?)
So, based on what I have determined so far, the wires should go like this:
Red - B terminal
Yellow - S terminal
Green - C terminal
Blue -
Violet -
White -
Black - One of the two "M" terminals? It previously went to the kill switch on my boat.
So, if anyone could fill in the blanks, or correct anything I assumed incorrectly, I would really appreciate it.
And if you're in the Cocoa/Port St. John area, stop by for a beer.
Red - B terminal
Yellow - S terminal
Green - C terminal
Blue -
Violet -
White -
