Gafisherman
- Joined
- Apr 28, 2011
- 30
Hey guys,
Have a couple questions on a 70 model 9.5 evinrude. I am working on it for a friend and I finally have it running, its prob been sitting for about 3-5 years. Anyways the problem is on the water i have nice water flow coming from the pee hole and then after running for a lil bit more smoke then water starts coming out of the pee hole. We can throttle it down and a good stream of water starts coming back out and then when we start back into the throttle it will start to smoke again after about 200 yds of travel. Just tryin to make sure if this is normal for a motor that sat for a while or it is a over heating problem. thinking that maybe the water impeller is dry rotted but it wouldnt pump water at all if that was the case right? thanks for any info
List of what i know:
Fire in both cylinders (new Plugs)
timing and points are set correct
65-67lbs in both cylinders
Water pump line is not stopped up.
