redfury
- Joined
- Jul 16, 2006
- 2,657
Re: Need some advice on transom materials
If you consider wind gusts and tarps climate control, then I guess you'd be correct
I simply wanted to make sure there was clarity as far as the need to stick to ratios and not delve from them very far just to get more time to work with the resin...Do it at night or in the morning when it is cooler out if you need more time from the heat...that's about the only shot I've got at it right now with my boat.
Well,living in minnesota probably helps too,lol...Im sure you have a nice big climate controlled garage so Im just messing with you.The resin to hardner ratio was more of a brain fart than strategy. Thanks for the reply though.
