fastryker
Thread starter- Joined
- May 3, 2011
- 9
I have a question. I recently purchased a 1977 Marquis Riviera Tri Hull project boat. Powered by a 140 Mercruiser 3.0 GM Motor. The old motor was seized from not running for 15 years. I soaked the cylinders with marvels oil overnight, and it turned right over.Good new oil in motor. Compression test was front to back 120,120, 60, 40, thought maybe rings stuck. Then After replacing the fuel pump, points, rotor, cap, plugs ect. got it to run a few minutes, won't idle though, I'm sure carb needs rebuilt, Then the starter quit. Replaced with new style starter, ran a few minutes again and got motor warmed up. Checked compression again, 120,120,100,60.I have already put so much money into getting this thing going, I hate to give up on it, or should I. My question is do you think I should run with it and see if the rings and compression improves? Or go ahead and have the motor rebuilt while I have it out and I'm rebuilding transom. Money is tight for me but I hate to have to remove the motor again. Not sure what to do. Or maybe I'm hoping for a ring spring back miracle. Your opinions would be very helpful as I'm an A/C mechanic by trade, not a boat mechanic, lol. Thanks, Mark
