Van Wildonher
Thread starter- Joined
- Aug 15, 2009
- 59
Hi guys, I purchased a boat that has been sitting a while it has a 200 and a 225 on it... Model numbers e200txetf and e225txerk now the thing is, the engines look like they are from 1986 according to the cowlings, lower units, carb hose route, etc. yet I believe these model numbers are 1993-94.
I don't have pics right now, but it looks like the lower cowlings were cut to be able to house the exhaust/garden hose flush hook up. Did the 1986 motors have a garden hose flush hook up?
I had the model numbers so I went ahead and ordered thermostats/water pump kits for the 1993-94 model. The 1986 models seem to have an o-ring that goes on the top of the drive shaft and no o-ring under the impeller, and the 1993 models have an o-ring that goes under the impeller and no o-ring on the top of the drive shaft. Of course I didn't notice any of this until I replaced the water pumps and and installed the lower units.
I did not notice any o-rings on the top of the drive shafts when taking them apart, there were however o-rings under the impellers.
Basically I need to find out what exactly I have here so I can know what to do. I'm also trying to find out if water is supposed to come out of the starboard side hose/pee hole things. This hose is connected to a throttle valve thing but no water comes out. (I'm running on muffs because I don't want to launch and haul if the water pumps aren't correct) This is the only hose connected to the throttle valve thing and it's not plugged. (it goes from the pee hole to the throttle valve) I didn't see a way where water would even be able to get into this hose.
The OEM manuals for the 86 and 93 don't show cooling hose routes that I can find.
PLEASE HELP!
PLEASE HELP!
