need some help - rusted nut and bolts
sailors hornpipe
i have a 1992 180 nitro fs - one of the ski hooks which is connected to the transom has been pulled loose by previous owner- it is u shaped - with the open part of the u going through the transom -the open part of the u becomes threaded bolts which are connected inside the transom with 2 nuts - problem is the nuts on the u hook are completely rusted as the po didnt use ss or galvenized nuts- they are in a very tight space and torqueing with all my strenghth will not budge them with a cresent or ratchet- i wonder if any of you know of a product or anything that will make them easier to remove - again the nuts are so corroded that they have completely rust welded themselves to the bolts - i have to get these off in order to drill new holes for a new hook as the hole is so wallowed out that the area maybe weak as i was told by a friend who knows boats- im a newbie- thanks for any ideas and input:D
oldjeep
Re: need some help - rusted nut and bolts
Heat them up with a propane torch and then spray PB blaster or your favorite lube on the threads. As they cool it draws the lube into the nut.
tupperj
Have you considered using a Sawz-All or cutoff wheel on the "U" on the outside? Cut through and push the remainder through the transom. Just be careful and protect the gelcoat!
ufm82
Master Chief Petty Officer
Dang- you beat me by a minute. I was going to suggest a cut-off tool- buzz off the round part and push them through. Great minds think alike!
UFM82
