Two part question here. 1984 Evinrude 8 HP outboard. Pull start only.
First: I had to replace some parts in the handle as a friend pulled it off and lost a few pieces, the helix twist grips and a roller. I have it all fixed now but the twist throttle does not let the throttle go back down. I can twist the throttle to wide open and it goes. When you try to twist it back there is very little resistance and the throttle does not change. If you take the cover off I can manually bring it back to an idle but not through the grip. Did I miss a piece that must have got lost?
Secondly: I started the motor for about 15 seconds to make sure it would run, and after it did start I killed it and noticed this...
Is this a major leak? I am guessing I need to replace a gasket to fix this. Sorry this is my first boat so I am quite ignorant when it comes to boat motors.
