I got 1986 70 HP Evinrude that dies when i shift forward but idle fine and reverse fine , When i shift to shoot of the hole it dies unless i slam it in full throttle it goes but some time it get a hiccup and die, When it goes I can back off the throttle then i will stay running around 3k RPM then I can go back to WOT ok but it seems like it will die below 3k .
Carbs been rebuilt 3 days ago there is no Needle valve slow speed that i saw when i took the carbs out i was told some don?t have it . Float was set to ?? like the kit say Am using external 6 gal tank w fresh gas, No fuel leak or crack?s in the fuel line .. ... ThaNKS
