need some help
bouch1
Hi all, I have a 93 force 120 (bayliner capri 18') it has been running great all season, until now, on the boat speedo it has been running about 42 wot until today, a week ago it was getting about 38 with similar load onboard and today only 30 with slightly more weight, it felt like it was running at about 60 - 70 % power at wot,took a bit to plane out and holeshot was slower, I have a new prop this spring and is now a bit dinged (2nd use after latest dinging up)and wonder if that would cause that much loss, also it looked like I might have too much oil in the mix too, how much would that affect top end? or overall power. no tach on it at this time so I don't have RPM # but I didnt hear any slippage from prop or high rpm at any time, wot sounded less rpm than before, any ideas? thanks for any help
bouch1
Re: need some help
what has me baffled is last use the prop seemed fine so am thinking more mechanical, but it ran well engine wise last time too, I recently put in a new impeller and tell tale and gas is recent, looking over engine briefly when i got home the spark arrestors on the carbs looked like they had too much oil in them (where a little gas usually is) that is where I saw that as a problem.
