Need some help.
jtracc
I have a 18' sting ray. The drain plug and flange is brass. I had some water get in the back from a rough day on the water. I tried to unscrew the 7/8" brass plug off and she wouldn't budge. I tried everything and couldn't get her off. Last resort was my impact wrench.. Ended tearing the whole flange and plug off the boat. So I was left with three holes that i fixed with some marinetex. My issue is I can't find another 7/8" flange and brass kit anywhere. If you know where please let me know.
Thank you
Re: Need some help.
Thank you
Ayuh,... Search up a Garboard Plug, 'n you'll find what yer lookin' for....
Btw,... Most Garboard Plugs are 1/2" pipe thread...
jtracc
Re: Need some help.
Can't find any 7/8". 1/2 won't work at all too small of a flange and oil tube won't fit through either. I can't believe no one makes 7/8" when it's on my boat.
Re: Need some help.
Ayuh,.... The OD of 1/2" pipe threads is 'bout 7/8"....
Don S
Re: Need some help.
attachment.php
attachment.php
smokeonthewater
Re: Need some help.
seems to me that you already HAVE the piece you need... use some heat to get the plug out, clean it up, and reinstall it.
