need some mercury help
bummy80
i have a 1988 2.5 mercruiser inboard that has been sittting for a couple of years. did the usual carb rebuild, drained the gas, new points and condenser, plug wires and spark plugs. also i cleaned the distributer inside, set the dwell and timing to specs. the problem i am having is running the engine on muffs i get a miss, bogging, and or gas misting out the carb at about 3/4 throttle. my tack does not work correctly so i am guessing it is about 4000 rpm and the max wot is about 4200 by the specs. my question is is this normal being run on the muffs with no load on the boat or do i have a problem somewhere? running out of thing to check or try.
Alpheus
Re: need some mercury help
You are kidding right? If you ran your boat at 4K RPM with no load its time for a new engine...
I would say you got a problem somewhere.
Dont do that!!!
Bt Doctur
possably a melted impeller not to mention floating the valves.
bummy80
it sounds bad the way i explained it, i was just testing the throttle response. i just did it a few quick times. my question is does it being in the water have a difference on the tuning?
Bt Doctur
Being at "no load" is not the best way to check an engine.The issue with hi rpm`s on a hose is that the pump cam actually suck so hard it shuts the water flow off from hose collapse, the impeller burns ,and now the hose is forcing water thru the system instead of sucking it. Once in the water you have a overheat condition.
bummy80
thanks for the reply, that answers some of my questions.
zbnutcase
Night and day difference between running on hose and in the water!
