Need some Suzuki DF140 4 stroke wiring help
parrott
I bought a 2003 Suzuki 140 four stroke from a guy. It was off the boat and I'm wiring it up on my skiff.
I have the tilt and trim working from the binnacle, the starter turns the flywheel. I took out the 4 spark plugs and laid them on the block. I'm not getting fire and I don't hear the fuel pump come on.
Attached pics show the wires from the ignition switch.
I also disconnected the kill switch to make sure that wasn't it.
Wire colors:
Pink/light blue/white: Tilt and trim
Ignition switch
Grey- Hot when switch is on. I would assume this would start the fuel pump.
Brown- Hot when starting. I assume for the solenoid for the starter
White- Hot continous
Green- Ignition and hooks to the kill switch
Yellow- I'm not sure of???????? There isn't a yellow coming from the motor harness
Harness coming from the motor
Bright Blue and Orange- Don't have a place or colors matching to plug these 2 in??? Anyone know what these go to?
Green
White
Lite Blue
Grey
I have the harness on the motor end plugged in(only the big connector and 2 bullet connectors(pink and blue, tilt and trim) That's all that was there.
Any suggestions? I did check the fuses (3) on the side of the motor
Any way to test the high pressure fuel pump?
