Need specs for OMC Trolling Motor
ego_55
Hello,<br /><br />Ijust got a used trolling motor, no stickers nor propeller, I found on the pedal the following info:<br /><br />Mod. No. HBFL2K<br />Ser. No. H2894081<br />OMC <br />12 VCD Hong Kong<br /><br />It has 3 speeds, and I need to find out the propeller replacement (original part number or which one would do the job!), lbs. of trust etc-<br /><br />Thank you very much for all your help.
OBJ
Re: Need specs for OMC Trolling Motor
Here ya' go ego....<br /><br />Made around 95'.<br /><br />Thrust is 26.5lbs.<br /><br />Standard prop - 8 3/4 x 3.8 PN115827<br /><br />Max Current draw - 34amps.
ego_55
Originally posted by OBJ:<br /> Here ya' go ego....<br /><br />Made around 95'.<br /><br />Thrust is 26.5lbs.<br /><br />Standard prop - 8 3/4 x 3.8 PN115827<br /><br />Max Current draw - 34amps.
Thank you VERY, VERY MUCH !!!<br /><br />Ego_55
