Need Suggestions about Placing Drain In Tahoe Q4 S/F
fdtiger
I have a 2004 Tahoe Q4 SF. I took the carpet out a few months ago, and I went with Durabak. I wanted to be able to spray the deck down when I finished fishing/skiing. I recently found a flaw in my plan. I do not have a way to drain the water once I spray the deck. Is there any way to install a drain. I know that the gas tank is under the center rear bench seat. I'm not sure if the area under the two rear side seats will drain anywhere. Has anyone tried this? Any suggestions?
tjlight
Re: Need Suggestions about Placing Drain In Tahoe Q4 S/F
Hey that was a link to my post.... hope it helps.. Just be careful when you drill the holes, the tank is just below the floor there. You do have about a 1.5"-2", so don't push too hard on the drill. If you have any questions feel free to ask. I'd hate for you to mess up your boat. I was reluctant to drill hole in my boat but the results are better than I hoped for. The water drains to the bilge area so all you gotta do is pull your plug or turn your bilge pump on while under way.
