Need Suggestions about Placing Drain In Tahoe Q4 S/F
fdtiger
I have a 2004 Tahoe Q4 SF. I took the carpet out a few months ago, and I went with Durabak. I wanted to be able to spray the deck down when I finished fishing/skiing. I recently found a flaw in my plan. I do not have a way to drain the water once I spray the deck. Is there any way to install a drain. I know that the gas tank is under the center rear bench seat. I'm not sure if the area under the two rear side seats will drain anywhere. Has anyone tried this? Any suggestions?
NYBo
Re: Need Suggestions about Placing Drain In Tahoe Q4 S/F
No ski locker?
fdtiger
No ski locker?
It has a ski storage, but it has a 1/2" lip. Installing a drain in front of the ski locker might be my only
option.
NYBo
option.
I'm not following. Where is the lip?
But right in front of the locker cover should work. Be sure the limber holes between the locker and the rest of the bilge are clear.
fdtiger
The ski locker door frame has the lip. I will probably go in front of
Of the locker. Sounds like the best option.
NYBo
Sounds like quite a trip hazard.:eek:
Good luck with the install.
